I had mine out a few weeks ago. Those plastic pieces do require a little force to get them off. The rear most ones come apart from the bottom first as the two halves have a tongue and groove that connect them by hooking the rear half from above the front half. So, don't try to pull straight off from the top. Pull straight away from the bottom 1/3 for best results. Once you have those plastic pieces off, the seats just require the removal of 4 bolts (two per seat) and nothing else. Be careful not to lose the rubber grommet on the alignment pin on the bottom attach point on the seat. For me, one stayed with one of the seats and the other was found loose in the back because it fell off when I was lifting the seat out. Also, check that the clips that hold those plastic pieces together get put back on the removed plastic pieces before re-assembly. IIRC, a couple stayed behind when I got them apart.
Oh, also, only one of the two halves comes off on the rear plastic. The other half stays with the seat.
