removing rear slider windows
Does anyone have any tips on how to remove rear slider windows on a 1997 fjz80?
351 looks and no replies? Not sure if their the same but I just did this on my 60. I used a dremel multimax with a straight blade almost like a butter knife. And from the inside you push the blade between the pinch weld and the window frame and work your way around.you should have someone on the outside.It cut through the previous glue/sealant like a hot knife through butter. It will smoke a bit. But worked great. After you get them out you should prime or paint the scratched metal to prevent rusting.i had Aussie style sliders that leaked, that's why I had to take them out to fix.
Good luck
Rich
