Removing PS Pump
So I was looking at the PS Pump today while I was cooking on the grill. Looks like the High Pressure Line will be a PITA to get off. Can I unbolt the pump and pull it down then undo the line? Or will it be to hard to loosen when the pump is just hanging? I thinking I will replace the High Pressure Line, but I'm not 100% sure on that yet.
do not make it more complicated then needs to be....I just replaced PS pump last saturday...first time got it done...and i did not suffer too much. Enough extension allows you to crack it loose with the wrench just above charcol canister. The hardest part for me was to remove bolt locking the gear on the pump. I had to ask Sear' mech to bump it for me with power tool - aside of that - easy done , 3 hours.
Andres
Ok well I got the PS done. I rebuild the PS Pump, and get a new High Pressure Line from Advance Auto Parts ($50 lifetime warranty). Drove it about 20 miles and everything seems to be good.
Sweet!! Got a part number on that high pressure line? It's always the achilles heel of this job. Thanks.
DougM
