Removing oil pan section from transfer case
Perth Australia
Hello first post here
I’m from Perth Australia, I own a 2005 hzj105 landcruiser wagon. Second owner have slowly been building it up, currently have 2 inch efs lift, 285/75 nitti grappler mt, dual battery, side steps, exhaust and extractors, few other stuff I can’t think of at the moment,
Anyways I was changing the oils on my car and when I was doing the fill hole bolt on the transfer case I over tightened it and have cracked the cast alloy threaded hole.. I have used a cold weld to hold it for now but it’s started leaking a little now..
I’m looking at my options..I can weld it up? Was also thinking of getting a second hand transfer case and and just taking the front section off where the oil is in? Saving me removing the whole case ?
So am I able to do this ? Just that the back section off what ehe oil is and swap it out with another from the second hand tcase?
Or do I still neee to remove the whole tcase do accses it ?
I’m just tying to find the easiest way to fix this that won’t cost me to much as i can get a second have tcase for $100 that’s wrecked but has the fill and drain hole side intacked ?
All replies appreciated
Go to Marlin Crawler website and look for lo range crawler gear for 80 and 100 series LC. They have write up on cracking case while on vehicle to replace 4lo gear set. if you have that t-case should give you all the information.
Mine is part time ? R box. Not h like turbo of 80 series
