I have been trying for a couple of years to free up the rusted LSPV with no luck. The nuts come off but the bolt is rusted to the valve. I just tried to remove the bracket but the bolts are going to break off before they come out.
If I delete the LSPV what will the front to rear brake pressure ratio be?
Right now its :
Front 2000 PSI
Rear 900 PSI
Thats a 69 31 front to rear ratio.
This is with an unadjusted LSPV and 2.5 Med OME lift.
Would there be any differences in braking if I removed or left in the ABS system hooked up?
I have the ABS unplugged right now.
Right now its :
Front 2000 PSI
Rear 900 PSI
