I am in the process of replacing my front rotors. I am wondering if anyone has a suggestion on removing the six coned shaped washers (wedges). I have tried tapping around them to see if the vibration would jar them loose...no luck.
Make sure you leave the nuts on while you're beating on the studs. This will make sure they don't go flying off to where you can't find 'em.![]()
I was getting ready to tackle the brakes and rotors when I asked the dealer for quote on front and rear brakes and rotors on cruiser LABOR ONLY and they said approximately $950. HUH????? What am I missing is this really that labor intensive?
Rear end is easy, front end is much more labor intensive...You are basically ~1/2 way through a full front axle service just to replace the rotors because the hub has to come off. You mentioned reading some threads but have you read the front axle service FAQ? That shows you how far you have to go pretty well. When you have it all apart it just makes sense to repack the bearings etc. so that only adds to the labor.
If you NEED rotors now but not the full front axle service then do it but if you don't need new rotors now then just replace the pads and then when you do the front axle service down the road that is the time to replace the rotors
As for the dealership cost...Dealerships charge a lot...Just the reality. If you can't tackle this on your own, try to find a local Cruiser head that might be willing to tackle it for you for less or help you with the work...Great way to learn.
Trying to find a local cruiser group for wrench session but not much luck yet.
It would be helpful to give us a general location of your existence....
That way we can give you a general location of the existence of a Cruiser Club.
I just replaced mine this past weekend, I could not get the cone washers to budge then I used PB Penetrating fluid and with a couple of hits the washers popped-out...sweet! Installed the Slee rotors.
a lot.
