Removing Factory Alarm
Will I run into any problems with removing the factory alarm on a 97 LX. I had a remote start put on the vehicle and sometimes the two systems get a little crossed up and it is difficult to shut the damn thing up. Would it be as simple as pulling the alarm head unit or would I need to try to remove the entire system??
Thanks
you may need to remove the starter cut relay and short pins # 2 & 4 for it to start after removing the alarm
The two should be able to coexist with each other, but if you really want to remove it it's not that hard. At the ign. switch there is a jumper harness where all the alarm power/starter connections are made. You unplug this and then re-connect the ignition harness to the cylinder and you will have effectively disconnected the alarm. You can go as far as to remove it all, but I think that's all that's really necessary. That's how my truck was. Yours may differ.
