removing driver side finder???
Murfreesboro Tenn.
how do you remove the cowl so that you can access the bolt to remove the fender? or is there something that we are not seeing? any tricks or lessons learned from others? Thanks in advance.
I see from your sig line you have an 89. Are you working on that or an 80 series? On an 80 there are 6 bolts across the front of the louvered cowl and then you have to remove the wiper arms. This should get you to the point you can remove anything else you need to. I couldn't find anywhere in my FSM that talked about fender replacement. This thread might be helpful:
https://forum.ih8mud.com/showthread.php?t=167506&highlight=remove+fender
Good luck!
Darius,
I have a 62 but in am helping my brother with his 80
There is a row of screws running across the front of the cowl that hold it and the cowl gasket on. Remove those. Also, remove both wiper arms. The cowl will then slide up over the wiper shafts, a bit forward and off.
When you put it back on, you might want to use some dish washing detergent or something slippery to get the back edge to tuck up underneath the windshield gasket. Having a helper on both sides when you do that is a must.
Rather than starting a new thread I thought I'd add something relevant and ask another question.
Found a leak (yes, it rains in AZ sometimes! :D) and am to the point where I want to remove the fender to look around. I already caulked an about an acre of the window trim and it appears that's not the culprit.
I stole this image off the web to use as an example for my '96 LX450. It appears I've removed all the bolts minus one or two near the circled area but for the life of me cannot figure out where they are. The top of the fender is loose enough for sure but down at the bottom I'm stumped. I even removed the steprail (the other side is coming off as well :D)
Any pointers on exactly where this fantom bolt(s) is? Thanks in advance!
EDIT: I should clarify I'm working on the driver side, and the red dots are bolts i've removed - but you probably already figured that out.
Here is a picture from inside the bottom of the fender showing the bolt locations. maybe this will help you.
Bill
Many Thanks Bill!
Yes, it appears that one bolt by it's lonesome there is the one I'm trying to hunt down. I'll start pullin' crap til I find it. :D
EDIT: Turns out I had all the screws out, but the "goo" that was attaching the inner to the outer fender just didn't want to let go. A little knife action and it was off. Also turns out the window molding almost near the top of the window was the culprit after some spot testing with a water bottle.
I used a bicycle changing "spoon" thing to pry it back and fill it generously with "bathroom" grade caulking. I'll post more pics of exactly where the water was coming in for future use... Just gotta put that wiper cowl/cover thing back on and I'm good to go. :)
