Well here goes.
It should be easy as I remember it on my old '74 but now that I am starting Ginny's take down I have run into a royal PITA. While trying to remove her doors on both sides the top door hinges the bolts came out with little effort. When it came to the bottom hinges the bolts that screw into the nuts (that I was sure are welded to the inside of the door) just spin. It seems the welded nuts all came loose from their welds.
So in order to get the doors off I ended up pulling the four bolts that go into the door frame. Now that fine as it got the doors off but…….I want to strip her down to derust her and prep her for fresh paint and thus the hinges really do need to come off the doors. Anyone have any ideas as to how I might go about it without splitting the doors or just cutting small holes near where they are to access the bad ones and then spot weld in new ones and then repair the holes? I certainly could use some input on this one since she is so straight and clean to this point. I just hate the idea of making new holes when I already have some I will be filling to begin with. I just haven’t run into this one before.
Thanks in advance folks.
So in order to get the doors off I ended up pulling the four bolts that go into the door frame. Now that fine as it got the doors off but…….I want to strip her down to derust her and prep her for fresh paint and thus the hinges really do need to come off the doors. Anyone have any ideas as to how I might go about it without splitting the doors or just cutting small holes near where they are to access the bad ones and then spot weld in new ones and then repair the holes? I certainly could use some input on this one since she is so straight and clean to this point. I just hate the idea of making new holes when I already have some I will be filling to begin with. I just haven’t run into this one before.Thanks in advance folks.
