removing cap
Victoria, BC Canada
I am trying to remove the cap of my hard top that I recently sold and the bolts are rusted tight. I have tried Liquid Wrench and tapping with a hammer now for about three days and no movement. Then I bought left-handed drill bit (a screw extractor) as I had read on the forum that it worked for some people...no luck. First of all, I can't access the nut on the other side (in the channel between the cap and sides)...it is too tight a squeeze for any wrench or pliers I have. Suggestions? Am I doing something wrong? I need to get this apart and sent off to the guy who bought it ASAP.
The nuts are captured, I believe, so no need to grip the nut. They were on mine. I just broke off the ones I couldn't loosen and drilled them all out, welded new nuts on. But I had the FG cap off the drip rail.
GL
Ed
pardon my ignorance
So the drip rail is the bit with a lip that comes up around where the screw goes through toward the top. It is that little bugger that keeps me from getting to the nut (which is irrelevant at this point if the nuts are captured. But because of the drip rail, I can't access the bolt to even cut it off. The bolts are in so tight they are almost countersunk so I can't get anything around the head of the bolt or under it either.
The nuts are tack welded on the top of the gutter, so there's no need to get a wrench on top, the bolt loosens from the bottom. If the bolts are that rusted most likely they'll break off pretty easily when you try and loosen them anyway. That's what I had to do on mine. Just get the ones that you can off, and break off the rest. It's a lot easier to deal with broken bolts when the top is off on the bench.
breaking bolts
Perhaps it's just me (but I am pretty strong), but I can't even get them to break!
Can't access for breaker bar
I can't get under the screw head to wedge off the head and break it that way. I also can't access the top of the screw (where the nut is) because of the drip rail and cap.
Get under the screwhead and wedge off the head? Are you trying to pull it apart? Just get a 12mm socket and just start torquing until they snap. I think I broke most of mine off with a 1/4" ratchet. They're pretty small bolts. There is no need to get to the captured nuts on the top side of the rail, you should be able to do everything from underneath.
heads
The heads for the bolts that attach the roof on my FJ are like screw heads. A socket wrench doesn't work with them. Today I am going to try a screw extractor with a tap wrench and see if I have more luck.
Try some Kroil by Kano Labs. It works great! I have used it on nuts/bolts that were so rusted they looked like one piece. Soak'em with it, let 'em sit for 30 min. and then try it.
FInally
:bounce2: Whew. I finally got the bolts loose. I got about half of them out tonight. I used a left-handed drill bit and a tap wrench. Thanks for all of the suggestions.
