Removing boggered crankshaft nut!
cruiser_guy
Out of Africa / North Africa
Wherever the truck stops!!
Website
join-hands-for-hope-helping-people-help-themselves.mailchimpsites.com
Anybody have any ideas for removing this nut (at least I think it was a nut once)? It looks like a mess to me, certainly no way to put a wrench on it.
Grind it off or???
Does anyone know how it looks if it would be ground off? Could I get the pulley off if I ground the nut away?
Also, how about a replacement nut? The engine isn't super critical as I'm leaning to swapping in a diesel but I'll still be going through the F with the shop class.
That is an early style, press on pulley.....1958 to mid 1969...there is not a nut on this, like the later style.
Thread two 8mmx1.25 bolts into the holes and install a T-bar puller, and remove it.
Good luck!
-Steve
Yep, those press-ons aren't hard to get off. :eek:
Good luck!
-Steve
Press on?!?!? I've never heard of such a thing. Seriously, is that even possible? I'd think they would fall off if they are pressed on. How do you reattach them? Does a steering wheel puller work to get it off? It still looks boggered to me!
It is an interference fit, was used for a long time that way.
Press the pulley back on... :)
If your steering wheel puller will span the bolt holes in the pulley face...
Yes, something has messed it up well.
Good luck!
-Steve
I used my steering wheel puller. You won't be using your hand crank starter on that one!
when it was time for me to put my press on hamonic balancer back on i drilled and taped the crank because i had my 1st one fall off on the 405 freeway. I used a lot of redlock tight it still there.... just a thought
