Trying to throw a new AC belt on and can't seem to remove the belt that goes to the air pump, loosened it as much and it's maxed out but still too much tension on the belt to remove it. Any ideas?
Have you loosened the tension pulley?Trying to throw a new AC belt on and can't seem to remove the belt that goes to the air pump, loosened it as much and it's maxed out but still too much tension on the belt to remove it. Any ideas?
First you want to loosen the bolt on the air pump, then it should slide down. Though mines a 62 so it might be different if its a 60If I remember right, I had to tap on the air pump to get it to move in
A trick ive used that isnt necessarily smart is to try to get the belt started coming off and crank the engine to pull it all the way off. Just keep in mind the rotation of the engine. I mainly use that to get a tight belt on but it works the reverse way too.View attachment 2065199
I can't get any movement past this point from it.
That worked thank youA trick ive used that isnt necessarily smart is to try to get the belt started coming off and crank the engine to pull it all the way off. Just keep in mind the rotation of the engine. I mainly use that to get a tight belt on but it works the reverse way too.
If you dont want to do that then you might have to remove the bracket that the pump is bolted too.
Anytime, which trick did you end up going with?That worked thank you
Cranked the engineAnytime, which trick did you end up going with?
Im glad it worked for you. i have to use that to get my AC belt on because my idler pulley adjuster is frozen in place and i cant get enough torque on it to break it loose without taking the front clip off.Cranked the engine
