Pretty soon I'm gonna be ready to reinstall the engne, trans & transfer case. Body's off the frame. So, do I bolt everything together and install together, or do the engine, then trans, then xfer case?
I have done it the other way (engine in, and then jack up the tranny and insert). It is not fun, or easy, and is not a one man job.
It's not almost easier.Trying to get the tranny to line up with the output shaft is a pia with the enginge installed. If you ever do find yourself in that situation, it is almost easier to remove the tranny hump and use a cherry-picker from the top to swing it into place.
