Okay I have no idea how to start this be here goes. I'm not new here but its been a real long time since I have posted...
I have a 78 fj40 (April). I have an alternator that I had tested and it is charging and good. I was told it's an internal regulator. HOWEVER up on the firewall I have a small black box that is labeled "Toyota 30 501". There are 3 wires going in to it two from the alternator (Wg and Wbl) and a third (By)I think this is a regulator. But the people at the auto parts store tell me my alternator in an internal regulator.... how is this possible??? You can't have 2 regulators..So are they wrong? The cruiser has been running FINE for 4 YEARS with this stuff.
I don't seem to be getting a charge to my battery.
So first is what is that black box? Second how do I tell if it's an internal or external regulator?
The part I'm speaking of looks close to this one https://forum.ih8mud.com/40-55-series-tech/378530-new-harness-voltage-regulator-amp-gauge.html
Except mine is reversed my capacitor is on the right not the left and 2 of my wires go to the cap and the last goes to the body...
Last all of this is because my cruiser will not idle. I have to keep the choke pulled out to make it run. At first I thought a vacuum leak but I replaced most of the tube, then did that starter fluid trick and got no jumps in rpms...any thoughts?
