Recovering an 80 without trees
Lincoln, NE
So... a lot of places nearby have a lack of substantial foliage. No trees. Rocks can be in pretty short supply too if they weren't deposited by glaciers 10,000 years ago. So, I've been giving some thoughts to how to self recover my 80 when I will inevitably get stuck.
The easiest way to prevent being stuck is obviously to be ready to be stuck. So, I've been considering two options.
1. Pullpal
http://www.pullpal.com/
2. ARB Portable Rescue Tree
http://www.arb.com.au/recovery-gear-other-by-arb.php
I like how the Pullpal actually assigns load limits and has some good endorsements. It is readily available.
I like the ARB recovery products that I have. I haven't seen the Portable Rescue Tree available in the US yet, but that may just be due to the speed of the boat. I like how it folds up and it has that evil-cool look, not that i'll care how it looks if I'm stuck.
What will work best with the weight of the 80 and the silty dirt and clay in the river bottom midwest? Opinions?
As for self recovery, has anyone figured out a good method of getting the winch line from the front (ARB bumper, Warn 12K) to behind an 80 in order to pull backwards without cutting stuff up with the cable?
Thanks!
them pullpals are big and heavy, tempting but what a pain...
I'll say this: the use of a couple of fixed snatch blocks, one up front, one out in the rear and then attaching the cable to the rear recovery point may lead to some surprises if you want to go backwards... :D
(but really, there have been some posts about the guy who ran the cable in the frame underneath)
I'll also say this: if stuck on a slope, do not attach the cable to a big rock just in front and above you... :D
You might get more input if you post to the Camping-Gear-Recovery forum.
Bridging ladders can be helpful if you can get the wheels jacked up, but I think a Pull-Pal is the safest and most reliable option. I recall some articles a while back that tested the various ground anchors, and the Pull-Pal won hands down.
take off your spare, bury it, and you will be amazed. Yeah it's work, but it will anchor the truck. You can also use the spare as an anchor behind two rocks and such..
There was a top gear episode where they used a pull pal, IIRC. It got a full size range rover unstuck from some pretty nasty looking marshy mud with some vegetation in it, pulling the rangie uphill. Before they made the pull I would've put money on the pull pal ripping out of the ground, but it seemed to work pretty dang well.
