So I did some work on the front end and had to get an alignment. Interestingly the print out I got, caster was blank. Which would explain why its rubbing really badly on the splash guard on the passenger side and on the side step on the drivers side.
So I wanted to ask if there was a recommended alignment spec? Because what Ive been reading is just 0 camber, 0 toe, and as much or little caster to not rub? Or is there a better spec that I can tell the alignment guy?
