I recently received my COMEUP DV-12s and I'm now attempting to get things ready for the installation while I wait for COMEUP to send me a replacement motor cap; the cap arrived cracked by, I assume, UPS. @COMEUP is sending me a new one and I should have it sometime next week according to the CS rep.
Anyway, this winch will be going in an ARB combo bar on a 100 Series and in order to use the freespool T-handle, I'll need to reclock it so I can get my hand in there. If mounting feet forward, I'll need the handle to come to the front of the vehicle by 40 degrees.
Now, I'm having a hell of a time trying to reclock this sucker. I've checked the owner's manual (which oddly enough seems to be for the Seal series winch, not the DV series, so no help here) and I've checked their website and YouTube channel, which again, everything seems to be geared towards the Seal series winch. I did find this page, however the instructions are so sparse they provide no help.
Could I clock the freespool T-handle position in your winch?
I've removed the 3 bolts on the brake cover and the brake cover itself, exposing the 6 bolts for the clutch assembly. I removed all 6 of these, however the clutch seems to be frozen together. I can slide the whole clutch assembly away from the spool housing, exposing the greased gear set, however I would assume this is not how you would reclock as it has three pegs that lock the assembly together on the spool housing and this would only allow you three T-handle positions at 120 degree increments. COMEUP states there should be 9 settings at 40 degree increments.
What am I doing wrong guys?
