Rebuilding the Front axle
Rubber gloves and lots and lots of paper towels. Not a difficult job, just messy. Don't disconnect the. Brake lines from the calipers and be sure the flats on the birfs are lined up when you install.
Get the Factory Service Manual for your vehicle.
An article I found useful covering front axle rebuilds Repacking CV (Birfield) Joints and Wheel Bearings
a rubber spatula is helpful for scooping out old goop from your axle, and helps with repacking birf.
Lots and lots and lots of paper towels. A fish scale to check preload or see Marlin's site for their version. Good torque wrench.
If you have to separate the birf from the axle for any reason (like installing Longs), then a 3' piece of 1.5" schedule 40 pipe works great.
I'm slow and set aside a day per side.
Got all of that except the pipe. Whats the pipe for?
If you have to separate the birf from the axle for any reason like installing Longs.
I always thought the pipe was for when you get pissed off you could hit it. (the pipe) :)
Chris
