So, in an Irish Whisky induced haze, I read a post on here about someone buying new headlight buckets because they couldn't get their headlights to adjust vertically. Being Irish myself, I immediately said to myself, "self - your headlights don't adjust vertically, either. Perhaps you should buy new headlight buckets as well. Looking through the Toyota parts catalog, I see new headlight buckets are in excess of $300 each.
Holey crap. Also being Irish, I thought to myself, "self, every dam other thing on this thing is rebuildable, so why not rebuild headlight adjusters."
I did a search of this forum, and came up with zip, null, bupkus.
So I went out to the garage, popped off the grille and the side markers and pulled out the driver's side headlight bucket. Sure enough, there was a perfectly rebuildable vertical headlight adjuster affixed to the back of it.
Two #1 phillips head screws later, I had the bugger off.
The next step was slightly tricky in my mildly buzzed state, so I very carefully spread the plastic back clips from the plastic and separated the two halves.
I removed the metal rod by pulling on it, being careful not to damage the plastic bits. I took out the first plastic gear, put an extremely small drop of superglue into the hole the rod goes in, and then reassembled it, being very, very careful to wipe up any excess that the rod pushed out of the bottom. Otherwise, the cussed thing would be glued solid. Here is where not putting too much superglue works to your favor. Any excess and you ruin it.
Then I simply put everything back in reverse order, being careful to allow the superglue to completely dry before dinking with it again.
Voila! A free 1 banana fix that saved me over $600.
