rebuild?
Socal/ I.E.
My cruiser has 185k mi. on it and I am thinking of rebuilding it before I have any real problems. what do you guys think is that something I should do? Or is it one of those things that I am better off not touching till it breaks.
I suppose if you have the time and money it certainly wouldn't hurt, but it doesn't make sense if you have no deteriorating performance symptoms or semi-global expedition planned. Even though the HG is something to watch, there are many 80s that see over 300k with no issues.
I think you can wait on rebuild unless you have problem such as hg failure sign or planning a drive around the world expedition like other mentioned. With proper maintenance it shoule last at least 250k or more.
Well, what is te general condition of the engine? Have you done a compression test, cylinder leak-down test etc? Had the valves adjusted? Seriosly, these engines can go a long time a take a lot of abuse/hard use without failing. You should be able to easily get at least another 15K miles before thinking about it if the battery of diagnostic tests indicated that the engine is strong and healthy. Let the engine tell you when to rebuild it.
