Rebuild or?
Thinking of rebuilding my 3fe from my 92 LC. Not ready to let it go for newer car yet. The truck ha s 235k miles, shows no signs of wear execpt for leaks from the usual seals and could use a new headgsket. I know that the 3fe is extremely durable, my question is, to what extent should I go to rebuilding or perhaps just light overhaul ie seals, gaskets, bearings and rings. If I don't need new pitons and rods then why pay for them. Also what psi range wise would indicate good compression from the cylinders. By the way, am going to rebuild the cylinder head as well.
Heres the specs for compression
Compression Pressure
Std 149 psi (1,030 kPa)
Minimum 114 psi (785 kPa)
Difference between cylinders 7 psi (49 kPa) or less
Thanks. On 3fe's, what should I look for as far as wear on the rod and crank bearings?
Is there really only 7 psi difference between cylinders? I'm not douting you but that seems really low.
do92fj80,
I was just presented with the same dilema. My 94 blew a HG last week. I could have simply cleaned everything up and thrown a new HG on and called it good. Mine only has 171K so the bottom end was pretty decent other than two worn bearings. I decided to drop some coin and rebuild the whole engine. Not many of the original parts are going back in. Call me anal, but the PO neglected a lot of things, and rebuilding the engine gives me the peace of mind that my 80 will continue to be as reliable as I expect it to be. YMMV
I can see where you would want that piece of mond. I don't want to go that route unless I have to. 3FE's are strong engines. I would just like to keep it simple. At this point I am going to do all gaskets including the head, and seals. Just want to know while there what should I look for? Which brings me to another question. How common is wear around the cylinders?
