Rebuild locking hubs?
Dallas
Website
www.octagonmma.com
Should I just buy new Warns or Aisins to replace what I have or do I rebuild them?
What's the smarter thing to do?
Coarse spline Warns are pretty cheap on ebay, but the rebuild kits are not expensive either. Simple job to do. Sometimes just disassembly and a good cleaning and a regrease will fix them. There is an O-ring that can go bad, allowing water in the dial.
By the looks of the hub, you have gear oil in the knuckle.
GL
Ed
are they broke?
or just something leaking?
do some searches on aisin hubs, i think it's in 79 that the birfields got shorter and they put the shorter aisins on. pretty sure some people have longer aisins (think on 55's). might be time for disk upgrade?
I'd pull em degrease and clean up. Like ed says you probably have an axle seal leaking which you should fix. The warns seem to grenade easier but you'll have to swap out some parts to run later fine spline aisins unless you find some elusive fine spile big body aisins off a fj55. Or if you have coarse you'll need to upgrade anyway.
I am going to degrease them first then see if any further necessary repairs are warranted, though both sides turn just fine. Leaky hubs are rebuilt now. This is a picture from when I brought my hunting rig home last winter, after taking it to the ranch in 1994-95. Looking for a suspension and wheels now that the frame and axles are blasted/painted.
