Rear wiper wiring missing (1 Viewer)
Eau Claire, WI
My rear wiper does not work. I removed the 2 metal panels on the lift gate and it looks like there is a segment of wiring missing. There is a connector in the small panel area and the wiring connector on the wiper motor but not connected or enough length. Any ideas on where I can get wiring to connect them?
Eau Claire, WI
Thanks, I’ll check it out. I see they have “rear wiring harness” at cruiser parts.net and not sure if this includes the lift gate wiring.
Spike Strip
No Malarkey
Los Angeles
You might want to put 12V directly to the rear wiper motor, first to see if it's working.
The harness for the Rear wiper motor enters through the top of the lift hatch and goes through a rubber tube/grommet . Is that still there? The harness may just be disconnected and flopping around up in the hatch.
Eau Claire, WI
The first 2 pictures show the wiring coming through the top of the lift gate with the washer fluid tubing. It doesn’t reach the wiper motor connector which is in the second 2 picks.
