Rear wiper relay
There's some sort of tan box (looks like a relay to me) under the plastic panel (remove 4 screws and op off as I recall) that runs the width of the hatch...my rear wiper is non-functiona; - i can hear that box click when I actuate the rear wiper. Maybe I should look into replacing it?
mine's a '94
It is located inside the rear hatch, remove the plastic cover and you will see it.
The wiper and the defogger were broken when I got my 80.
The relay in my cruiser was full og water and rust. So were all the other plugs inside the hatch. I opened the relay, dried it and soldired wires over the damege in the printed circuit board.
I also cut all the rusted and corroded plugs away and soldired the wires together. Cleaned the plug into the relay, filled the relay and the plug up with vaseline and plugged it together, and everything worked perfectly.
Now I have a rear wiper and a defogger ;)
