Rear wiper not working
When the hatch of my lx is closed and on occasion, if the whisper switch is on it will move when the hatch is open. But as soon as the hatch lock makes contact with the tail gate lock it stops moving. Does anyone know if it is a short in the wire and if so how to fix it?
Probably a broken wire in that rubber sleeve that goes to the hatch from the body.
^^^^^ This
Connector between switch/relay or relay/motor?
Mine works when the backseat door and rear hatch is open. But when you push the switch in the rear door jamb the wiper stops immediately.
I also noticed the inside lights are not turning on when the rear gate is open. Could that switch be broken and causing this problem?
In mine, the rear defrost didn't work - they share a ground (white with black stripe) that had melted a bit in the connector hidden behind a relay in the hatch. The connector is a 2 wire connector covered in foam, if one side looks dark, probably the problem.
I tested mine by having the trim off and running a jumper cable from a ground in the cab to wiper motor itself (with it working just fine that way), then worked my way backwards.
