I started having problem with the rear washer. Regardless of pressing the front or rear pisser it would only spray from the front. I replaced the diverter valve last year due to the common double spray problem. I found a blue check valve that was in the rear tubing below the rear jack holder that is restricting the flow. It has a small metal ball and spring. I cleaned it out with brake cleaner but it still will not work. I can't get the ball to move by blowing trough it only by passing water under high pressure. Do you really need this I replaced it with a normal double barbed connector and all is fine. Now I'm thinking this might be another reason everyones diverter valve went bad. The other failure is using water instead of washer fluid which I believe rusts out the metal disk in the valve diaphragm, just my 2 cents.
George
George
