rear window roller popped out
My left side rear window stopped working today, so I popped the panel off and took a look and the roller has popped out of the guide. What is the best/easiest way to get it back in. (I got it in the back side of the slide, but obviously this is not the correct position because the window will only go a little more than 3/4 of the way up so I assume I need to get the roller into the back of the slide, but have not been able to do this)
I have searched but either I am not searching for the correct term or I cannot find it. Any help would be appreciated as I cannot get the window up and I have the door dismantled, and this is a daily driver
Thanks
puddles
I figured it out
So what did you do? What was the trick?
Someone, like yourself, might be searching for an answer to this and come across this thread and get nada unless you add some content :hillbilly:
I had problems with this for a while. I'd put it back together and a few months later the roller would come out of the track again. I finally figured out that the track itself was shifting on the bottom of the window. If you grab the track you can shift it (its tight but it will move) enough so that the roller won't roll out the end anymore.
Aaron
I used a prybar. If you're really careful, it's a lot easier. It'll deform the inner door frame a tad, but no one's gonna see it.
It usually only has to move 1/4 - 3/16".
To get the roller back in the track, I just loosened the bolts that hold the arm/roller thing to the door frame. Then if you use the switch to move the arm to the right position you can pass the roller back into the end of the track it came out of.
Aaron
I had the same issue on mine. My temporary solution was to unplug the up/down switch. That was like a year ago. lol. I have no rear passengers besides the dogs...so no worries!
