Rear Wind Diffuser
Has anybody attempted to remove the rear wind diffuser/deflector and brackets to re-acquire and achieve the "finished" look?
If you take the wing off there are 6 holes in the body with brass(?) inserts, similar to the roof rack holes. The truck looks unfinished with the holes... seems like a lot of work and money to remove them.
Kind of what I figured but didn't know if anyone had any clever ways to fill in the holes (rubber gromets or plugs or something...)
thanks!
thanks!
Several have removed the wing and the roof rack and replaced with a variety of stainless rosette caps etc. You might search under "roof rack" and possibly cross reference member "cruiserdan" as I believe he had something along those lines.
thanks!
I personally took the stock bolts, matched them to short bolts at Ace Hardware, painted the new short bolts, and screwed them in to the stock holes with a bit of RTV.
any concerns with rust or do you have grommets or something to keep the moisture out?
He's from AZ, I don't think they have too much in the way of rust issues there.
is there a link that has alternatives or suggestions for removing the air diffuser?
