Rear upper control arm bushing size
Camp Verde Az
I have searched and have come up with all other bushings, but I can not seem to find the outside dimension of the bushings in the rear upper control arms. Its snowing I need to make a press tool. Anyone know the dim.? On a side note I have been here a while, and until now ALL of my issues and concerns regarding the build of my 80 have been covered. Thank you all for such a wealth of knowledge :cheers:
The arm that I have has the bushings in it, so kinda hard how much chamfer there is on the bushing/arm. I would make it a hair under 2", call it 1.990", to push the bushing all of the way out it needs to be at least 1.75" long. If your using solid stock it will need a relief in the face for the bushing tube about 1.25"OD x .325" deep.
thanks
thank you. I felt axle rotation due to worn out heims I will be cutting my 4++ upper arms to accept a stock bushing instead of heims wich are 1.75"od. I replaced the heims about a month and a half ago so I figure just cut and press, I should be free of rear axle rotation and clunking.:grinpimp:
