I’m dealing with the annoying issue of flickering overhead lights, and it appears that it is related to the switch in the rear tailgate. Bumps in the road as well as banging on the upper tailgate cause it to flicker. I’ve tried adjusting contacts and catcher to try and get the latch to maybe hold better, but no luck to this point. Does this switch have issues like the doors and I just need to replace it, or is there something else I should be looking for? Any suggestions are definitely appreciated. Thanks.
It's either mechanical (adjust the striker) or electrical (ground fault maybe?). If you can get the switch to work by hand, it's probably not the switch.
The switch is built into the latch assembly that is directly behind the handle to open the hatch from the inside.
The light works by the switch grounding the circuit IIRC. If there are any shorting issues in that line before is gets to the switch, it could cause the circuit to go to ground and the lights to flicker when it does. Most likely place to look for that is to check the rubber cover on the wiring for the hatch from the body to it in the upper left corner of the hatch opening. If it's intact, it may be elsewhere, but if there's a tear or other damage of that cover it could expose the wiring to damage.
On the interior lights the switch IS the ground. When door opens it allows switch to complete the ground, making lights come on. If you have a flicker, you need to check the wiring coming back to the switch in the door, somewhere.... it’s either “nicked” or cut, allowing it to make intermittent contact, flickering the lights.
