Rear Sway bar axle housing bolt size Solved.
opg4759a
KB6FJ /AE
SF East Bay
So I acquired a FJ62 rear sway bar for my 85 FJ60, I have all the parts except the bolts that go to the axle housing. I've been searching and searching but I can't seem to find that actual size bolts I need to mount the rear stabilizer bracket to the axle housing.
All the bolts on Toyotas are metric.
The most common size for the most common bolt is M8x1.25
Remove a bolt from somewhere else on your vehicle that will fit where you need it. Once you find a bolt that fiits, take it to the hardware store to match up
Or better yet - get a thread checker
Damn you guys are good. M8x1.25 20mm are a perfect fit for the rear stabilizer bracket to the axle housing.
Any pointers on doing this install on whole? I swear I had previously seen a thread on this can't seem to find it. Cheers for any help.
