Rear sub and lighter charger question
West Pacific
Did a search but I was looking for a thread how to on accessing my LX570 rear sub behind the rear right panel.
The sub is rattling and I need to get in there to hopefully seal the speaker foam to mitigate the noise.
Also, my usb charger plugged into the cigarette lighter is not charging my phone...yes, I have the 110v button actuated on the lower left driver side dash. Any clues?
The 110v button on the dash is for your 110v outlet in the rear driverside of your truck. Open your hatch and look between the hatch and the rear seat.
If your 12v outlet on your dash isn’t working, check the fuses. There is a fuse block under the dash, where the 110v button is. On the cover of the fuse block it shows which fuses are in which location.
Yep, checked it out. The 15A fuse for the cigarette lighter is intact.
Man, that was a pain to take out.
It looks like a short leg fuse similar to these:
Now the question left unanswered if that pesky rear sub.
Anyone know how to access it?
No, not a stupid question.
I swapped out the iphone charger cable and charger.
Still no luck.
My only option at this point is to open up the center console and check for a loose wire.
