- Joined
- May 17, 2003
- Threads
- 43
- Messages
- 187
When I put my lift on today I couldnt get the bolt/pin out of the rear spring hanger like i did with the others. the others just hit right out with a punch and hammer. well i tried with this one and it didnt work, so i put the bolt back on a little bit and hit it with a hammer and started turning the whole bolt at the same time. it worked but when I got the bolt out of course the threads were all messed up. soo my question is can I get a new one of these or should i try to re-thread it. and if not could i just knock that pin out of that wierd shaped end peice is has on it and put a bolt through there, or will the bolt not hold. its pretty funny that just about everybolt is original, and basically none of them gave me problems, most came out as if they were just put in. incase your wondering its the lower bolt that holds the spring in.
Thanks
Thanks
