Rear spring height
I have a set OME 863J springs in the rear of my 80. The ride is really stiff as expected, but the passenger side rear sits a good 1-2" higher than the driver side and is also significantly harsher going over bumps. I didn't install them, I bought the truck like this. Is this normal, could it somehow be seated wrong? The springs are relatively new and still have the tags on them.
Any input is appreciated.
It's likely that they were improperly installed, what do the tags say? One spring is taller than the other, probably need to be swapped side to side.
x2. The taller spring is supposed to be mounted on the drivers side to ride level with driver and fuel tank weight.
They both have OME 863J and the one on the driver side says o/n 410925 (I think) and has an X on it. I can't see the passenger as well, but there is an Emu picture, I don't see an X on it.
Swapped the springs yesterday. You guys were right, improperly installed...rides 100% better and sits level now. Thanks!
