Rear spring Conversion, no light?
Charlotte, NC
I did the XREAS delete and replaced the airbags with Dobinson rear springs for ~2" lift. I unplugged the shocks and replaced them with the 5100's. Then I disconnected the air lines from the air tank using the caulking cap method. I took it for a drive expecting a trouble light to flash at me and there isn't one. The height level light is on "N" as if nothing has happened. Is this normal?
Yep. No warning lights should come on. You can pull the relays to get rid of the ride height light if you want.
Cool, thanks for the response. I kind of like having the light on. That way it seems "correct".
