Rear Sliding Window Vent Removal.
Lake Havasu, Arizona
Does anyone know how to remove the rear sliding window vents without removing the window assembly so I can replace them? I can’t find any videos anywhere on the tubes.
Thanks.
If you're referring to the glass panels, they pop out. The instructions are in the service manual.
Thanks.
You mean the black plastic vents on the rear? If I recall correctly there is 1 nut on the inside. (behind the inside trim). The rest is secured with plastic trim clips. This can be removed without removing the sliding windows.
X2
That little nut in the quarter panel is a pain to get at as it’s small and tucked up high in the space.
