That's what I made for mine. I did not cover it with sheetmetal to avoid the wicking moisture problem that was built in with the original design. I measured the length of the old piece, tapered the ends and made some kerf cuts with a hotsaw. The kerfs were not enough to make the bend so we used a cutting torch to cut some "V"-shaped notches. Also since I used square tubing, I had to cut some access holes for the body mounts. Since I used thick wall tubing, I just drilled and tapped for the spare carrier.
Sorry for directing you to something that wasn't what you needed.
GL
Ed
