rear sill wings required?
Hello,
I have a rusted out rear sill.
I see rear main rear sills sold with or without the winged ends.
If I am going to change out rear 1/4 panels do I need the rear sill "wings" as well?
I searched and read many posts, even the great one about the use of 2" square tube.
It seems that the wings are only needed if you are using your existing rusted 1/4 panels.
Thanks for any tips.
The "wings" are also body mounts. They are pretty easily fabbed from 2" square tubing, if you have a torch and welder, nothing to it. There's certainly lots of cruisrs on which they have rusted away, but they do have a purpose.
I didn't 'box' my wings when I did my version of the 2" box rear sill replacement. I just welded on a couple pieces of thick sheetmetal (2"x8"x10ga?) hand bent to match the curve of the fender.
IIRC, I needed them for support for the dual spare tire racks' lower hinges. Otherwise I probably would have left them off.
Not needed but recommended. Are you going to fab your own sill? I'm getting close to that point know but I'm not spending 100+ bucks for a lousy piece of sheet metal.
Item 250071268056 Item 250071267722
These are the sills I sell on ebay, They're under 50.00. It replicates the outer skin only, no inner channel. I have about 4 of each left and won't be re-ordering, if anyone's interested, I'll give a mud discount. They aren't drilled. Mods, if this isn't Kosher, feel free to delete, thx.
