rear shock ?
West Georgia
anyone ever tried cutting holes in the bed of a fj40 and mounting those f250 shock mounts in the back? i'm working on a trail only rig and am wondering if it would give me more travel? or not worth the trouble?
okay then why does it allow a few more inches of articulation on the front with the f250 mounts and longer shocks then?
i'm doing a soa, stock springs, nothing radical, it just seems like the stock way of mounting the rear shocks, even if you move the top bolts in and the bottoms ones out doesn't allow much shock travel at all and you have to have long bump stops to keep them from bottoming them out, maybe if you had more shock travel then the only limiting factor for the bump stops would be where your tires crunch sheet metal, that or the limit of your articulation?
I run the long ranchos (5012's I think) in back with a SO and can not use all their travel. The top mounts were moved in, But I will probably move them out to the stock location to get more dampening. The lower mount is on the back of the perch, basically behind the axle.
My front shock mount is on top of the tube (stock location).... this makes for a short shock body to keep from bottoming the shock out (and a short body means a shorter extended length). The front still flexes great, but it is limited by the shock at droop. One day I will swap the the taller ford towers and a longer shock, but the rig gets on down the trail pretty damn good now.....
PMK
HawkDriver said:
When talking about the front articulation, did you get more stuff or droop with these shock mounts?
The shock mount can not give you more stuff or droop. A properly designed and selected shock and shock mount will allow you to maximize your travel.
You need to controll the distance the axle travels up (stuff) and down (droop) with the shocks disconected. Controll the stuff with bumpstopps to stop any negative arch that may happen. Now....... measure your travel from stuff to droop and select a shock with more. Now mount that shock using wahtever mount allows you to place the shock so it does not bottom out or fully extend during articulation.
HTH,
PMK
