I was installing the rear ome shocks with the ome bushings on my stock 73. These are the shocks I bought in ~2000 and they’re basically unused (life hot in the way)and seem to work well. Only problem is they’re a bit to wide to fit on the stock studs. With the bushing fully compressed, I’m only getting a couple of threads into the nut. Did the bushings swell over the years of unuse? I tried to use the nut to compress the bushing with mixed results. Driver side worked, but I still can’t compress it enough to insert a cotter pin. Passenger side ripped the threads off, so I can’t get a nut on with the shock in place.
This is the question: I need to replace the studs(mounts?) with some thing longer. Is there an off the shelf solution for this? Is there a better option since I’m cutting and welding anyway.
