Not quite sure what you mean. My emergency brake will not be on. There are two threaded holes on the rotor. Do I need to do both of them or only one?
thanks
thanks
You will not get the rotors off without backing off the emergency brake. There is a little rubber plug on the hub - remove it and spin the rotor until the plug is at about 6 o'clock. Shine a light in there and you'll see a small metal wheel with teeth. Use your screwdriver to spin the wheel (up to loosen if I recall). This will back the shoes off the inside of the rotor so it can be removed. Once the new rotor is on, you'll have to spin the wheel the other way until you feel a slight drag.
You only need one, once it breaks loose usually comes right off. Comments about e brake are because even when lever is down the pads are close enough to potentially bind up when you go to pull the rotor. Unfortunately know this one first hand, had to fix and repair one side on mine. Wish I had read and got this advice before I did mine instead of just jumping in like any other rear brake service I had ever done.
Changed out a busted rear lug a few weeks ago, 2lb hammer and 3/8 drift did the job nicely. Restarted the new lug with washer packers and new lug nut, wheel back on then pulled the lug bolt home easily with a torque wrench at 50-60 ft lbs. You will feel it seat in and then take the nut to 100 ft lbs or whatever your preferred torque is.Rotor is off
Now all I have to do is punch out the stud with a big hammer
