- Joined
- Aug 7, 2011
- Threads
- 12
- Messages
- 129
The biggest issue with rear radiators is getting them bled. Make sure that you have a high point in which to fill and bleed. On a rear rad configuration, you make have to make an auxiliary hose or tube to do this. Maybe a thermostat housing with a radiator fill built in? I found that although a stock style mechanical pump will push the water back to the radiator, the engine temps stayed more consistent with a good electric pump. I went through 2 of these and ended up spending over $300 to get one that worked as it should. Make sure to shroud and fan the radiator correctly as putting it in the back does not help a cooling issue much. On my truck I ended up taking the thermostat out and using a restrictor instead to control water flow. That took a few tries as well to get correct. I tried thermostatically controlled fan switches, water pumps etc, and nothing worked as well as the fan and pump running all the time. My engine was a 4.7 V8 and the radiator was a stock Toyota 4.5L radiator laying on its back. Pics are on my build several years ago under Project X.
