Rear pinion nut?
Fairfax, VA
As I was setting up my new gears over the weekend, I stripped 3 pinion nuts trying to crush the new crush collar. Well, I finally got it to crush to correct specs(12inch/lbs)PPL. My dilema now is that my last pinion nut stripped right at correct spec. So what I dont know is will a factory pinion nut from Toyota fit a 529 pinion. I dont know if its the same size. I found a Toyota dealership about 2hrs away that has some instock, I just dont want to go there and find its not the same size. Can anyone help me on this, I really need to get truck back together.
Thanks
I start crushing the sleeve in the press. Stand the unit on the flange, push on the pinion gear, rock the housing as you push until most of the play is gone, than finish with the nut, works great.
I found the CV nuts for front wheel drive cars work great. The one we used has a big flange (doesn't need a washer) and a good staking ring. They are commonly available at import part stores and made for big torque and loads. The aftermarket gears that I have seen have a different size thread, the stock nut doesn't fit. It looked like part# 87-1461 on this page.
EMPIUS.COM : 2004 A/C CATALOG, CV JOINT BOOTS, RACK & PINION COMPONENTS
Tool R Us, thats funny, I went to autoparts store and did exactly what you are talking about. I took my old 456 pinion and matched it up to a axle nut from a front wheel drive car. Wish I had thought about that before I stripped my last pinion nut. i spoke with Kurt at cruiser outfitters this morning and found that there are several diffrent pinion nuts for early Landcruisers.
:cheers:
