Rear motor mount hardware
Near Austin
I'm trying like the dickens to find replacement bolts, castle nuts and cotter pins, but I'm having little luck.
Are these parts NLA? Does someone have a super secret stash they'd be willing to part with? What are my options in the event that I can't find a replacement?
Are these worth reusing?
thanks! I looked for hours trying to find that.
Currently, there are none in inventory. Of course, it is 13mm fine thread. Mine probably got toasted by ignoring the toasted ones for the front mounts.
Any good sources on 1/2-20 x 3.5" grade 8 bolts and nuts for my '75? Or should I just use a 1/2-13 grade 8 and double-nut it? I am going to drill for a cotter pin either way?
Wait a minute. I just realized that there is a '5' on the OEM bolt, which I assume is a low tensile strength fastener. I guess that they were engineered for fatigue resistance and not tensile strength? That would make Grade 8 a bad choice from a material (not manufacturing, i.e. cut vs. rolled threads) perspective?
