Car:
2016 LC w/ 135K on the clock. All OEM except the Toyota front strut spacer. OEM tires.
Issue:
I can hear a metallic clanking around 10-15 mph as I let off the throttle (like on a neighborhood street). I can only hear it with windows rolled down, which tells me the two pieces clanking together are not connected to the cabin. There’s no sound inside even with AC and radio off. Been tracking down over the past few days but I first heard it a couple of months ago while walking down the driveway and my wife was pulling up in the car.
Things I’ve tried:
I’ve crawled under and tried to shake various suspension parts. Nothing seems loose
I’ve checked spare tire and it’s tight. The chain does dangle , however and that’s my main suspect at this point.
Zerks last greased 5-6K ago and driveline seems tight.
I’ve jumped up and down while stationary to see if it’s shocks/springs and shook the LC side to side. Seems to happen only while moving. There’s nothing I notice in terms of looseness or stability while driving. It’s as tight as ever.
Could the brake pads be the source? Sticking caliper that has a sudden release…? Could the spare tire chain be swinging around and clanking? Next stop is to get it on the lift and tap with a rubber mallet but I wanted to get some input just in case I’m not the first.
Thanks in advance!
Issue:
Things I’ve tried:
Thanks in advance!
