Rear Main Seal
I have seen lots of posts about the head gasket, PHH and things like that. However, I haven't found many posts regarding the Rear main seal.
I am trying to decide if I am going to do my timing chain slipper and the head gasket. My concern is that once i seal up the oil pump leak that my rear main seal may go.
How common is it for the rear main seal to leak?
when it does leak, is it a really bad leak or just a couple quarts a month type of leak.
246,000 miles and "hopefully" counting.
yes, I had similar situation to that other thread withmy old Volvo 850. Only I didn't know any better back then and the dealer let me waste all kinds of money on it until the very end.
Is there somebody that sells a good replacement eninge for the 1FZ-FE? I tried finding them and could seem to locate. Seems it might be better at this point to possible swap the motor or at least calculate the cost of that vs the cost of doing all the work and still having a problem.
If the rear main leaks, it's typically more of a seeping, not very much.
There are many other leaks/seepage that will appear to be a rear main, when it's not.
If you're using less than Mr. T's specification (1 quart per 1k miles) I wouldn't worry about it.
Drip.. drip.. drip
Hi, I have 197k on my '97 LX450 and counting and a chronic rear main seal leak. It has leaked when the PO owned it as well. To fix it (per the searches I have done) requires dropping the transmission which is outta my league (for now) as a DIY project, but the advice here on mud in general says, "let it leak". I just keep an eye on my oil levels and so far no problems. It leaks and uses about a quart every 3,000 miles. Not too bad, other than I have to be careful not to park in the driveway to avoid the wrath of the :princess:. Seems pretty normal to others' experiences that I have seen here on Mud as far as oil usage and/or leaks. I am a newbie, so please seek out others' opinions, but I have chosen not to spend the money right now on the rear main seal. I do have a bid to get it fixed though that you may find helpful; it's "booked" at 8 hours labor, OEM Toyota rear main seal $45.64 plus tax) C-Dan or others I am sure are cheaper. 5 qts ATF for $29.85 cuz you have to drain when replacing.
Hope this helps. -Shane
I rebuilt my engine right before 200K. Rear main has very minor leak. Input shaft seal on the tranny was leaking more.
Probably the easiest thing you can do to preventatively stop oil leaks is to make sure your PCV (Positive Crankcase Ventilation) system is in good condition and free from clogs. What this does is use the engine vacuum to relieve the excess pressure from heat in the engine block and head. When this system gets plugged up, the pressure in the engine builds up and eventually pops a perfectly good seal. The "pop" can be from a small leak to a gusher. I would recommend having a look through your manual (hopefully you have one - otherwise the Haynes manual is OK for our trucks) and getting familiar with the PCV system.
Trust me on this as I learned it the hard way. I finished replacing the rear main on my Volvo 240 only to have it start leaking again because the PCV system was clogged up.
-Phil
