rear main seal
Centennial, CO
engine seal help
How many :banana: is it to replace the rear main engine seal? Dealer's trying to charge 1k for service. Any opinions?
Hey bud.....check out the search feature.
Use the search feature:
go advanced: type-rear+main+seal/then select 80's section/hit enter
*below is a thread I found using it*
Hope this helps:http:
//forum.ih8mud.com/80-series-tech/188038-price-repair-oil-leak.html
Noticed that your asking about ability to change the seal....might wanta understand whats invloved in changing it....there is ALOT of work involved in changing it but if you have time & tools.....thats up to you.
Use the search, but I think I remember the book time on this repair is around 10-12 hours. You need to drop the transmission to get the rear main seal out (I think), which is a big, time-consuming job.
How did they/you go about determining it was, in fact, the rear main? Much more common is the upper oil pan arch seal - a bit easier, but no less time-consuming or less costly for a dealer to do it. You need to make damn sure it is the rear main before you pull it all apart. Otherwise, you should probably just go ahead and fix both to make sure you got it.
Lots of threads on this; could be the pan leaking, could be the seal, could be both. Both could be made worse by the type of oil you use, etc. If not bad and just a messy seep, consider switching oil brands/types and watch it. Many mudders swear by the Synthetic Rotella 5W-40. For conventional oil, I have used the Valvoline Maxlife 10W-40 which seeped less than my usual fill, the Mobil 1 10W-30 (or 40)High Mileage. If no time or money to replace it, you could try Bars Rear Main Seal Repair; comes in a grey plastic quart bottle $10 at Advance Auto,etc. Just use it instead of a quart of whatever you use at the next change. You can buy a lot of make-up oil for $1000.
My rear main was bad, made a mess of the driveway. I think Lexus got me for about 1,000. The toyota dealer in reno wanted 800 to fix it. Its all labor. The seal is about 30 bucks :/
