Rear Main Seal install, potential problem
Lubbock Texas
In the middle of a complete rebuild, and I received my gasket kit yesterday. I decided to install the rear seal while waiting on the block. I put a little grease on it and tried lightly hammering it in to the seal retainer, and it acted as if it was slightly oversized, and I couldn't get it to start seating. I walked away for about an hour, and when I returned, I was able to press the seal in with just my fingers. It acts now as if it is a bit undersized. It's not loose enough to fall out, but I can definitely move it with strong finger pressure. It is about 60-70 degrees in my shop, so no temperature extremes. Has anyone ever experienced this when installing the rear seal? It is an ITM seal. Should I worry? Hope this makes sense.
