So I'm trying to track down some leaking oil on my SBC. I'm getting oil coming out of my flywheel cover, and the flow seems to be increasing. I dropped the front drive line and removed the cover.
A while ago I thought the cover on the tranny side was loose so I tightened those up. This time, that side was fairly dry, just oily residue. On the engine side I couldn't see any evidence of oil dripping from the shaft between the engine and clutch. The whole inside of the bellhousing is covered with oily residue. So I'm really thinking the rear main isn't the problem.
The next place I went was the oil pan. I got my torque wrench out and found that most bolts were not tightened down to 12 ftlb's. Now today, oil is worse then ever, I'm guessing I must have increased the problem by crushing the gasket more?
Am I crazy in thinking it's not the rear main and quite possibly the oil pan gasket? Like I said, nothing more than some oily residue inside the bellhousing, my fingers didn't get wet oil on them when I reached in and felt on the engine side of the clutch and shaft.
