Rear locker
Holladay
Quick question. I've searched but I just want to make sure cause this is probably the most intense mod I've done.:beer: I want to install the factory locker in my rear. So if i get a third member with a locker, swap that, swap the ps axle with a longer one, modify the housing, add all the necessary electrical stuff (wiring, ecu, and switch) is that it? I don't have alot of knowledge with this kind of stuff:doh: so any advice would be helpful?:cheers:
Yes,that is about it. Few studs need to be swapped but it is really very simple. Check FAQ and call CDan for parts
You on Bainbridge? if so I could lend an hand with the swap.
